60 Pound off of ebay but seems a bit small compared to the ones other users are running
I was planning on giving the rocker cover a blanket around where the intercooler sits to keep the heat from directly warming it as otherwise it fits very nicely and doesnt leave me with a bunch of pipesHi @Fantastika
I ended up with the setup in the photo.
After a bit of research, I did not go with the one in your photo as it would have rested on the engine, hence introducing more heat.
If you can find a good mounting spot away from the engine, you should be okay.
More info on my setup can be found here: LJ78 | Family Camper Build | NZ - https://forum.ih8mud.com/threads/lj78-family-camper-build-nz.1291066/page-2
That definitely sounds like a plan!I was planning on giving the rocker cover a blanket around where the intercooler sits to keep the heat from directly warming it as otherwise it fits very nicely and doesnt leave me with a bunch of pipes
I looked at some videos and the barrel type seems to run warmer. Found this video in one of nomadtribe's threads so now im not sure. I would definitely prefer going with the barrel as itd be a lot less messyI’m beginning to plan out my intercooler install on my LJ71 and was set on a square core unit, but after giving your idea some thought, it would be an overall cleaner install. If you decide to go through with the barrel cooler, please let us know what the results are like![]()
I like the look of this setup. Its very clean. Where did you put the water cooler?Hi @Fantastika
Thanks @HouserI like the look of this setup. Its very clean. Where did you put the water cooler?
