Looking for a dash switch with extra lamp
OZ
I'm chasing a heater or demister switch or any switch with the extra light in it like the heater and fan switch pictured, but I want one that fits the spare holes in the dash, not like these which are part of an assembly, does anybody have any switches like this on your dash or console holes anywhere, if so could you post a photo and the particulars of your vehicle. I will then try to get one from a scrap yard. Thanks in advance.
TD100 -
What "hole" in the dash are you trying to fit?
The rear heater switch cover (84731-60010) fits in the blank you have pictured. If you pop the blank off you will find a working rear heater switch. The cover just snaps onto the existing switch. It lights up when you press it, but unless you have a rear heater doesnt do much more.
Here is a pic...
Thanks mthomp6,
The four switches pictured above are all in a module or block form, I'm chasing a single switch with one only extra lamp like the Rear fan switch, all the switches have a lamp in them for night driving and I want one with the extra globe that signifies that something is turned on. The position I want it for is one of the standard switch blanks around the steering coloum or shifter (lower centre console) which are larger than the position pictured above, not like the ones in the centre dash which are a complete modular assembly of 3 or 4 switches.
I pulled a 3 switch assembly out of mine and it did not have the switch components mounted behind the spare centre blank, it just had the modular block attached to the other switches but with no switch and they are not a separate part here. I have not pulled the 4 switch assembly to check it as as I expected it to be the same as the 3 switch assembly. I do want a seperate switch for next to the steering coloumn above the big blank/front or rear diff lock switch. The 80 series had the seperate heater switch with extra lamp but the switches are wider and different and I was hoping to get a 100 switch to drop in with minimal change except filing of the locating tag off the side and adding a sticker over the existing writing. The picture below is pinched from Siglo's post, it shows where I would like a switch basically, any of the top 3 positions but with the extra light, not just a sub fuel switch or other similar one.
