- Thread starter
- #41
Is that the orig 61 carb with the larger window but not blue plate or is that another one you had ige?
It's a sweet original rig and i'm finally glad it's in your hands. I thought Timm was going to mod it all up.![]()
The tub is the cleanest early one I've seen. Even the rear sill is rust free.
Is your IDIOT light for the oil pressure lit? Can you T in another oil pressure gauge. You might have an oil can handy to lube up that rocker assy on your next fire up. I would bet if you two cleaned up that carb a bit and loosened all the flappers, it would not need to be bottle fed. Love to see old forgetten cruiser's wake up! John
Would the boss object to you using the dining room table?
Speaking of idiot lights, is the oilpressure idiot light supposed to light up with the ignition on? Like the charge light does? Which ours does not...
lower flapper is still stuck closed.
Yes it should light because there is no oilpressure when the engine is off.
