Leveling LX570
Saskatoon, SK
Hi Everyone,
Is it possible to raise the front suspension to level the truck by just adjusting the front sensors without having to use OBD to adjust AHC parameters afterwards?
Thanks
Michael
Yes, it is possible. However, I recommend using some paint to mark the original set-point on the bracket, just so that you could return to origin, if things don't work as planned.
You just need to loosen the bracket (two open-ended 10mm wrenches, if I recall), move it, and retighten. The process is very simple, but you will impact the compression and droop of your suspension if you make large changes.
