LED Light Wiring Question light with 2 modes to Auxbeam switches
Tacoma, WA
I have a wiring question I'm hoping some smarter person can answer for me.
I want to buy some LED lights for my new bumper, and these lights have two modes if wired with a 4 wire harness. Mode 1 being a running light, and mode two being the full light output. The factory wiring harness comes with a two mode toggle switch (= 0 -), but Id like to wire it to my Auxbeam panel. Is there a way I could make use of the AUXbeams ability to program a button as a momentary on (toggle) function to switch between the two light functions? Some kind of relay or fancy electrical board I could wire in line to switch between the two modes?
Greetings.
I wired similar lights to aux controller
I ran the wire that determines the color to each of the relays for the button on controller then the common wire or ground was ran to each of the relays.
They shared the common and then the trigger wire was the other side.
Noomentary unless you hit the button to turn off right after turning it on.
