The clutch master cylinder on my 68 FJ40 is leaking between the plastic reservoir bowl and the cast iron body of the cylinder. I have tightened the internal nut, but that does not seem to have helped. The cylinder is new--I replaced it because the other one was doing the same thing. Can I put silicone or something similar in the joint as a sealant? The cylinders are from BAP. Could that leak be the source of air getting into the system making it necessary to pump the pedal to work the clutch?
Thanks,
Ernie
Thanks,
Ernie
