I finally put my rig back together yesterday after getting a rebuilt carb, recurved dissy, headers (with desmog), milled intake manifold, and all new Toyota tune up parts.
I put everything back together yesterday and I'm 99.9% sure I put all vacuum lines back together accurately. I fired it up and it started and ran OK, but when I drove it home, it had no power. It had a slight backfire as well.
Now to the questions: With a desmogged engine, can someone confirm the routing of the vacuum advance lines off the disssy? The desmog diagrams show that the outer one goes to the back of the carb, and the inner goes to the HAI (I can't figure out where that one goes). Finally, it looks like there is a vacuum line coming off the top of the carb cooling fan. Pre-desmog, it came and connected into the fuel cutoff and into the intake vacuum(R side).
Also, I put the engine on TDC, marked the dissy (and block) and pulled the dissy out a few weeks ago. I did not move the engine, and thought that I put it back in exactly as I pulled it out. If I got the dissy in 180 out, would I assume that it would not even run? The only way I could keep the vehicle running smooth is with the dissy cap turned completely CounterClockwise (retarded??).
So, can anyone help me out. This has been a long time coming, so both my wife and I would be very grateful to get this thing running. Thank you.
