- Vehicle Model
- 55 Series
- 60 Series
- 70 Series
- 80 Series
- 90 Series
- LX450
- 100 Series
- LX470
- 4Runner
- 4Runner Gen3
- 4Runner Gen4
- 4Runner Gen5
- GX470
- Prado 120
- GX460
- Prado 150
- 200 Series
- LX570
- GX550 / 250 Series
- LX600
- Minitruck
- T100
- Tacoma
- Tacoma Gen1
- Tacoma Gen2
- Tacoma Gen3
- Tacoma Gen4
- Tundra
- FJ Cruiser
- Sequoia
- Highlander
- Other
- Location
- Lake Oswego, Oregon United States
Bought this New in box, installed it on 08/28 Have not used it yet
Like Brand New
2024 redesigned all new James Baroud Odyssey M in Black
Going a different direction, my loss (this JB Odyssey M Black is $5,995 NEW
A Steal at $3,495 OBO
call me with any questions 503-970-1008
Can bubblewrap/cardboard/pallet and help with shipping if you are not able to pickup
SPECS
Shell: 4mm ABS with UV coating
Fabric: 3 layer blackout fabric with premium thermal and sound insulation
Mattress: 65mm (2.5″) High Density Foam
Size¹: 140cm x 200cm x 100cm
(55″ x 78.7″ x 39″)
Weight²: 65kg (143lbs)
Capacity: 2 adults and 1 child
¹ Internal measurements
² Without Ladder. 3% weight variation due to handmade manufacturing process.
FEATURES
Thick and Resistant Shell
Comfortable High Density Mattress
24h Solar Powered Vent
360º Panoramic Views
Up to 5 year industry leading warranty
3 Layered Patented Fabric
Complete Blackout
Unmatched Thermal Insulation
Enhanced Noise Reduction
James Baroud Odyssey rooftop tent from the Frontier range combines the best features of its predecessors and enhances them with new ideas that make the overlanding experience even easier, making it probably the best hard-shell rooftop tent on the market.
The Odyssey M with panoramic window measures 200cm in length, 140cm in width and 100cm in height when open, or 33.5cm when closed. In it, two adults as well as a child will find enough space for the night, but also, for example, enough room to move. So it´s perfect for family camping! Due to its light weight, the Odyssey roof tent can be mounted by two people and fits almost all cars.
The most significant change to other roof tents is the new way of opening & closing, which is due to several changes. Firstly, there are only two buckles for closing, and secondly, a new patented closing mechanism of the four automatically opening hydraulic pressure dampers brings a more convenient way of stabilization. They are adjusted or released by means of light pressure and an audible click. Opening thus takes only a few seconds, while closing takes around one minute.
The hard shell is made of high quality, 4mm thick ABS by thermoforming. It is heat and light resistant, has a UV-resistant acrylic protective layer and has been tested in extreme weather conditions - making it a durable product that impresses with quality. The new streamlined and aerodynamic shape reduces possible noise caused by wind or strong gusts. The available colors are metallic gray, black and white.
The 3-layer roof tent fabric creates nearly 100% blackout with zippers closed and defies winds of up to 120km/h. The fabric is waterproof and has a sewn-in mosquito net. Another novelty is the modularity of the roof tent fabric, because each of the 6 parts can be replaced individually. This especially simplifies the repair of minor damage by eliminating the need to replace the entire fabric.
The external functions include the solar-charged, battery-powered fan, which helps against moisture and prevents mold. Through an integrated battery, this works up to 24h - even without sunlight. The included telescopic ladder can be transported in the tent while driving and consequently does not consume storage space in the car. It comes with its own bag and has rubber feet for better grip on slippery surfaces. The maximum carrying capacity of the ladder is up to 200kg.
In the roof tent there is a new high-density foam mattress, which with its 65mm thickness provides a soft and cozy base for a restful sleep. The comfort is reinforced by a PVC floor covering. The magnetic LED lamp provides ample illumination at night with multiple modes and light colors, and can be charged via USB and attached by its own bracket. The roof fan provides comfortable air conditions at different temperatures by circulating air. Through the roof net, which provides space for two sleeping bags, for example, and several interior pockets, there is enough storage space for other items. You don´t need to worry about space shortage while camping!
Under the bottom are 4 C-rails, making the positioning and attachment to the loadbars variable. Loadbars can be mounted on the roof tent, which create space for luggage such as surfboards, solar panels or kayaks.
Update!
The New Versions of the Odyssey Rooftent come with 2 additions (as of Feb 2024)
Comfort Strip, & 2 front buckles
3-layered
UV, heat and water resistant
includes mosquito nets
100% blackout
double stitching
Why is it important to have tightly stretched walls in a rooftop tent?
Better Ventilation: Tightly stretched fabrics provide better ventilation. Air molecules are smaller than water, and when high-performance fabrics are tightly stretched, air can pass through while water stays out. This air circulation significantly reduces condensation inside the tent.
Less Moisture and Mold: Loose fabrics and wrinkles hold more moisture and are more prone to mold and bacteria. A tightly stretched fabric allows water to run off better, prevents standing water, and ensures a drier, healthier tent environment.
Why can't every manufacturer offer this quality?
High-Quality Materials: The specially developed Frontier fabric offers 100% blackout and outstanding thermal and acoustic insulation. The fabric has been extensively tested to withstand repeated stretching without performance degradation. That's why we offer an industry-leading 5-year warranty.
Experienced Craftsmanship: Our sewing team has decades of experience working with heavy industrial textiles. Precision in fabric cutting is crucial – deviations can be no more than 1.5 millimeters. This level of perfection is achieved only through years of practice.
Durable Seams: Our seams are reinforced with a flat-felled double-needle stitch. This technique creates an extremely strong bond and minimizes the risk of tearing, even with repeated stretching of the fabric.
Like Brand New
SPECS
(55″ x 78.7″ x 39″)
FEATURES
Complete Blackout
Update!
3-layered
100% blackout
double stitching
