The Klune-V Extreme Underdrive Goliath is an extremely strong two speed gearbox (direct and 270% reduction) that bolts in between the transmission and transfer case.Allows a Full Size HD truck to crawl at tractor speeds. Like a Jeep rock crawler.The Klune-V “Goliath” is now available to fit a wide variety of [...]
The Klune-V “Goliath” is now available to fit a wide variety of vehicles. Originally developed for use in rock crawler Jeeps and such, the line has been extended with large shaft, super strong models to fit GM, Ford, Dodge HD full size, including 23, 31, 32, 24, 29 and 34 spline apps. It can also be used as an adapter between one make of trans and a different T-case, in custom buildups. Drive shaft coupled apps for 2wd or divorced apps available. For your application, check the website or call!
High Impact Transmission and Gear
888-316-2940
www.high-impact.net
Link
888-316-2940
www.high-impact.net
Link
