iptman
Hello everyone,
I've been working on putting together a tool kit that contains most of the tools you'd need to service your Toyota truck away from your home garage. I wanted good reliable tools that I felt were several steps up from Harbor Freight and yet way less than the tool truck tools. I settled on GearWrench since they had almost all the tools I was looking for and I could get just the tools I wanted and nothing more. The only items GearWrench doesn't have and which are not in the kit is a set of JIS cross-head and flat head screwdrivers (I personally like Vessel Tools) and a 54mm hub socket. Here's the list of tools that is included in the kit.
3 Pc. 1/4", 3/8" & 1/2" Drive 84 Tooth Teardrop Ratchet Set
1/4" Drive Extension 2"
3/8" Drive Extension 3"
3/8" Drive Extension 10"
3/8" Drive Wobble Extension 6"
1/2" Drive Extension 5"
1/4" Drive 6 Point Standard Metric Socket 10mm
1/4" Drive 6 Point Standard Metric Socket 12mm
1/4" Drive 6 Point Deep Metric Socket 10mm
1/4" Drive 6 Point Deep Metric Socket 12mm
3/8" Drive 6 Point Standard Metric Socket 10mm
3/8" Drive 6 Point Standard Metric Socket 12mm
3/8" Drive 6 Point Standard Metric Socket 14mm
3/8" Drive 6 Point Standard Metric Socket 17mm
3/8" Drive 6 Point Deep Metric Socket 10mm
3/8" Drive 6 Point Deep Metric Socket 12mm
3/8" Drive 6 Point Deep Metric Socket 14mm
3/8" Drive 6 Point Deep Metric Socket 17mm
3/8" Drive 6 Point Metric Flex Socket 14mm
3/8" Drive 2-1/2" Spark Plug Socket 13/16"
3/8" Drive Hex Bit Metric Socket 10mm
1/2" Drive 6 Point Standard Metric Socket 14mm
1/2" Drive 6 Point Standard Metric Socket 17mm
1/2" Drive 6 Point Standard Metric Socket 24mm
1/2" Drive 6 Point Deep Metric Socket 19mm
1/2" Drive 6 pt 21mm deep Impact Socket
1/2" Drive Impact Extension 5"
10mm 12 Point Ratcheting Combination Wrench
12mm 12 Point Ratcheting Combination Wrench
14mm 12 Point Ratcheting Combination Wrench
17mm 12 Point Ratcheting Combination Wrench
12mm 6 Point Combination Wrench
14mm 6 Point Combination Wrench
17mm 6 Point Combination Wrench
10mm x 12mm Flex Head Flare Nut Wrench
15mm x 17mm Flex Head Flare Nut Wrench
4 Pc. Mixed Dual Material Plier Set
Fixed Tip External Lock Ring Pliers
1/4" x 11" Long Taper Punch
1/2" x 6" Cold Chisel
Oil and Grease Seal Puller
1/2" x 7" Brass Drift Punch
16 oz. Ball Pein Hammer with Fiberglass Handle
1 lb. Brass Hammer with Hickory Handle
As it's listed above the tool kit cost is $495 plus shipping.
I made this kit because I wanted something that could live permanently in my 80. I looked all over and couldn't find anyone selling a JIS-based set of tools like this. Once I put together the list and bought my set I figured I'd see if anyone else would be interested in a comprehensive tool kit for their Toyota.
I'd also be interested in feedback if you guys think I'm missing a tool that absolutely must be in a kit like this. I'm also considering smaller kits with just the ratchets and sockets and maybe just the wrenches. Let me know what you guys think.
Thanks for looking.
Thanks for looking.
