Jeep For Sale:
1976 AM General Postal Jeep DJ5D: 232-inline Six Chrysler TF727 Dana 44 3:07 Posi
History:
I bought this Jeep Back In December of 06. I bought it because I had always wanted one. It’s has been my daily driver since I bought it. I drive it on average 10 miles a day. When I purchased the jeep I did some research and found out that it was originally part of the postal system in Chattanooga TN. I am selling the Jeep to Cut my expenses and focus on my samurai.
New Parts:
In the course of owning the jeep I have replaced the following things:
Remanufactured Master Cylinder (Previous Owner put on new front brakes).
New Fan Belt
New Water Pump
New Head Gasket set
Head Surfaced and pressure tested
New Valve Stems Seals
4 New Shocks
New Upper Radiator Hose
Changed Rear Differential Fluid 80w 90-Limited slip
New Dash Lights
New Exterior Light
New Rear U joints
Flushed and filled Brake system with DOT 3
Oil Change
Coolant Flush
New Plugs
New Air Filter
I have all the receipts from the work I have preformed on the jeep.
Parts Included:
It was my intention over the course of the next year to convert the jeep to 4-wheel drive.
I have 2 sets of wheels and tires so a total of 10 Wheels and tires
1974 CJ Dana 30 Drum Brake front end 373 ratio
Dana 44 Trac-Loc Carrier with 373 ring and pinion
Speedometer Cable
Used But Very good condition Clutch Flywheel and Pressure Plate for 232-t150
Old School Chilton’s 45-81 Jeep manual.
Ball joint Lower
Stereo with 2 speakers
What it needs:
The jeep will be needing the following:
Ball Joints 3 I have 1 included they are about $15 a piece at Napa. Jeep Currently Drives fine with what is on it.
Exhaust Hanger There is in a intermittent noise from the exhaust banging against the shock.
Bottom Line:
I bought the Jeep for 800 dollars locally with none of the above work done or extra parts. I have over 500 dollars in all the extra parts. I need to get out of the Jeep for $1100.00 I would take 900 cash and some samurai parts. Please email me at Smigeski.5@osu.edu or call me at (440) 666-5649. I can send you pictures and you can come drive the jeep. The jeep is located in Columbus, Ohio.
- Jason
History:
New Parts:
New Fan Belt
New Water Pump
New Head Gasket set
4 New Shocks
New Dash Lights
New Exterior Light
New Rear U joints
Oil Change
Coolant Flush
New Plugs
New Air Filter
Parts Included:
Speedometer Cable
Ball joint Lower
What it needs:
Bottom Line:
- Jason
