Build Jacks 40 to fake 45 build
Trimmed the lower sheet metal. Should get a bunch done with the 3 day weekend.
Unless the coming storm brings snow to my local mountains, then I am going wheeling.
Also got my title today.......win.
Body mounts: Not sure what you are using but I used hockey pucks on mine in 1995, no issues for 11 years then she got parked. It was my dd and off road beast.
Here is what i used i had to do a body lift to make the body fit on the modified and extended 55 frame so i machined some tough material Delrin to what i was needing. the bottom spacer will be remachined with a thicker piece to take up the space on the underside of the body mount. Hockey pucks thinking worked out well material is tough.
Great work as usual Jack! Have you mentioned where you’re planning to mount the fuel tank?
Ok, how did that happen? In post #81 the larger radius was on the right in your mock-up, now it’s on the left?
