(Issues) Steering Intermediate Shaft No. 2
NY
Hi all. Need your expertise for someone who's familiar with the steering column and its parts.
After having bought the LX with hardly any steering, these items were already addressed:
• Leak from rack, replaced rack.
• Flushed power steering with Toyota Dex fluid, twice.
• Replaced PS Pump + Reservoir...replaced fluid again.
• Loose DS inner tie rod, replaced both inner + outer tie rods.
Finally read either on here or other forum that the intermediate shaft #2 (lower) U joints are probably to blame...mine is pretty rusty so I ordered one. In the meanwhile, I crawled under and stuck my arm between the inner tie rod and cv axle and sprayed down the U joints with white lithium grease. While not fully perfect, I'm guessing I'm getting about 90% of what the steering should feel like. Here's the problem. I also grabbed the shaft and wiggled/moved it to check for play. It looks like where it goes into the firewall...or maybe shaft #1(?), there's considerable play. I don't have another LX to check so I'm wondering if anyone has any input on this? Is this normal? If not, what parts am I looking at buying? The diagrams are pretty confusing.
I recorded a video from the top and hope this shows better. Link HERE.
Thanks all!
Same issue but with 2005 LC...will follow back up if I find something definitive...
White lithium grease actually worked really well...too well, even. While I definitely feel the grittiness of the rust in the U-joints, there's almost no more resistance in steering. I've since been lazy to actually carry out the replacement. Thinking of tackling it in the next few days, so I'll share my experience.
Did you end up replacing the lower intermediate shaft / u-joint. I’m getting ready to replace this shaft in my 05 LX. Like most of my projects, usually spend some time researching best methods. For this repair, I can’t seem to find any tips on best way to access lower yoke. Can anyone advise? Looks like from underneath might be best, but front diff housing is kind of in the way.
I ordered a new intermediate shaft and dropped it off at the shop that normally does my front-end alignments. They took care of it. The old shaft would lock up on left turns and was dangerous to drive.
