I recently replaced my carb with a new toyota carb hoping that it would correct an intermittent hesitation/surge problem that I have been having on my 85 FJ60I thought it was fuel system related, but I am thinking now that it may be an electrical issue. I will just be cruising along and all of a sudden you can feel a hesitation/surge and then back to cruising normally. It almost feels as if you were bumped from behind. I have replaced, carb, fuel filter (twice) and all hoses but it still does it. I was told to replace the temp sensor (near the CAT) and also to run the rig without the tach connected. Apparently, this is a common problem. Someone else suggested that it could be a loose ignition wire or the fusible link. Does anyone have any suggestions as to what could cause this?
