Ideal air pressure??? (1 Viewer)
Louisiana
What’s the best all around air pressure to run in my 33x10.5 x 15 BF Goodrich All Terrains T/A KOS ? The max is 50 psi. Looking for good ride and even wear .
Depends on the weight of your truck.
I run those on my FJ40 at 35 psi on-road, but mine is heavy (aftermarket steel bumpers and swing-outs, winch, skid plate, roll cage, etc.).
i would go around 40, but i generally liked running my tires at a higher pressure. i had e rated tires and ran them 65-70 most of the time, but i was also hauling metal in the truck most of the time so it was pretty heavy about 6k loaded.
you can also mess around with the pressures and see what works best for you and what your doing with the truck
FJ 60 with factory bumpers , no add on’s .
I run 33/35 front/rear. They are E-rate. Any higher and the ride suffers significantly, but I'm also very heavy w/X-heavy springs.
Think you'd be good starting @ 35 and going up or down depending on how they wear and ride quality.
Using a laser temp and doing a few test runs see what the tire temps get up to. Too warm, add pressure. Ride too harsh and tire temps are barely above ambient, could prob lose some psi.
did you get this figured out to your satisfaction? do it old school low tech. basically a 1" wide band of chalk across tread n play with pressure till chalk is wore off evenly across the tire. i'd have your average amount of weight in the vehicle during testing
yeah, you'll have to reapply chalk a time or 3
Tire pressure calculator...
No really.
Why are you here?
Do your own work FFS if your field of fu$$$ grows bare.
