rusty_tlc
Dain Bramaged Member
Got a new thermostat, gasket, and seal.
After I install that stuff I'm hoping the 60 will get into the normal range without 75% of the radiator blocked with card board.
Even with the engine temp in the normal range the heat is still tepid at best. The supply and return hoses get hot so there must be some flow. The fan is moving lots of air so I don't think the core is clogged.
While I have the radiator drained I plan to remove the valve and make sure it is opening.
I also plan to flush the heater core out.
Anything else I should check while the system is drained?
barely a trickle made it through.
