If you want a bolt on kit that takes all the guess work out and is top notch call Marlin
Most hy steer kits come with a new tie rod and drag link + rod ends. the reason they come with new rod ends is because they up grade to FJ80 rod ends. FJ80 rod ends are much cheaper to to replace and beefier.
If you want to go cheap and mod the stuff you already have give W a call Our Services he heats and bends your arms for soa. I had him do a set on my FJ40 years ago and have never had a problem.
If you want a bolt on kit that takes all the guess work out and is top notch call Marlin Marlin Crawler: Selling HySteer™ Kits since 1997!
A plus with Marlins kit is you get a new pitman arm that's about an inch taller then stock(helps to keep the springs from hitting the draglink)
brakes and steering is the last place you want to cut corners.
