HP/ Torque #'s
Speed demon!
Ouch, I imagine mine could only be worse after 200k miles. These things apparently made 212hp from factory.
Any other info about the dyno run? What kind of dyno, what altitude, etc etc
I would love to dino mine since the swap put a lq9 with a tune @ 420 horse 400 pound of torque at the flywheel have no clue what I have at the rear wheels
Never dynod mine after the rebuild and over bore. But I totally believe it's around 120-130whp based on weight transmission and 0-60 times
Truck has 170k (former metaltech 80), Mustang awd dyno, 256 ft elevation, 38 degrees ambient temperature. This run is about as accurate as they get.
The engine made 212, but put a big heavy transmission behind that. Then put a big heavy transfer case behind that. Then put two big heavy axles, both getting power behind that. Then some 31" tires. Then a big heavy frame and body on top of all that.
I have seen quite a few dyno'd and they usually fall between 120-135awhp and about 175-190ft/lbs. seems like this is a low reading dyno but the torque still seems a little off. But yeah definitely not power houses. Lol.
Here's mine. Bone stock 5500' altitude, superflow dyno:
scan0001-jpg.1226085
IMO, who gives a hoot what the dyno says, every dyno is different, every dyno operator has his own "correction factor" regimen. If it feels like it's running strong, it's probably go the same real-world power as any other 1fz-fe out there. Does make a good case for LS swap if your motor ever tuckers out though.
This might be an embarrassingly stupid question but wouldn't the factor that it's turning all 4 wheels effect the results of the horsepower to wheels numbers. Seems like you would have less horse power going to the rear wheels if you are also sending power to the front wheels. Maybe I am clueless on this. I have never dynoed any vehicle. The only Dyno machine I have ever seen use the rear wheels only for testing. I wonder if the results (on that machine) would differ if the tcase was locked and the front driveshaft taken out. Just a thought.
Yes, you are correct. The same motor will produce a lower whp number if AWD compared to 2wd. For instance 2 DSMs with the same tune, one being AWD, the other being FWD, the FWD might make around 5-10% more whp.
It's called "drivetrain loss" and the more conviluted, heavy and complex the drivetrain is, the more "drivetrain loss" there is. Another example. A fwd sr20 nissan will make more whp than a rwd sr20 assuming the same tune because the fwd transmision is more efficient and doesn't have to spin a long driveshaft. Same reason you can remove a steel driveshaft from a mustang, put in a carbon driveshaft and see a slight bump in rwhp in the very same vehicle under the same conditions.
Yes but that loss can be accounted for when they apply their correction factor.
These numbers don't surprise me. Big heavy engine, crank, long stroke, heavy transmission, heavy transfer case, heavy everything actually.. Not surprising.
The problem with correction factors is that they are 100% subjective to the dyno operator. Any way you cut it, a more efficient drivetrain will put more of the engine's power to the ground. And our 80's have just about the least efficient drivetrain of any mass-market vehicle I can think of :hillbilly:
Its funny, you really can feel that valley between ~2700 and ~3200. Its also easy to see why there is some debate as to whether the power peak happens at 4200 or 4600 rpm, because it doesn't seem to matter much.
The TQ curve on this is pretty impressive (given we're talking about tractor motors) actually. Essentially from 2500-4k its making max TQ. HP...well...we wont talk about that curve too much...
Now if only those #'s had 80-100 added to them, that would be perfect.
Honestly though, sometimes the lack of power gets to me. Then I remember its a Land Cruiser and I bought it because it can drive me 6 hrs to a mountain, drive me up said mountain where I can unload all my junk, then take me home after I am done. All of that in soccer mom like comfort and without much fear of failure.
