HP/ Torque #'s
Just want to clarify for some folks who like to throw "conversion factor" out there like some sort of magic phrase; the numbers measured are wheel HP and Wheel TQ. The figures are "as measured" with no conversion for altitude/ temperature/ drive train loss, etc. Measurements were on an AWD dyno, not a converted 2wd.
<iframe src="Facebook" width="560" height="315" style="border:none;overflow:hidden" scrolling="no" frameborder="0" allowTransparency="true" allowFullScreen="true"></iframe>
yea I think we all got that. Conversion factors or correction factors are exactly what @Heckraiser stated. They are the best guess by the person running the dyno as to what the actual crank HP may be. There is no exact science that sets those factors in stone, you can run your car on two different dyno's and get two different numbers. Or you can run it on the same dyno and have a different person run it with their own set of calcs and come up with different numbers.
The best way to get an accurate crank horsepower number would be to have the engine out and run it directly on a regularly calibrated Superflow dyno or similar.
RWKW and RWNM
Cliffs notes via google: 206hp and 420lb ft Daaaaaang :cool:
There is some magic going on, on that dyno graph. ;)
At 1850rpms where he has the peak torque it looks to be ~570Nm.
Convert Nm to ft/lbs. 1Nm = 1.355ft/lbs so 570/1.355 = 420ft/lbs.
And then HP = (ft/lbs*rpm)/5252 so (420ft/lbs * 1850rpms) / 5252 = ~148hp But this dyno only shows 108hp....
I would guess there is a calibration issue with the dyno.
I did wonder about the calibration of the dyno to be honest, but anyway...
FWIW, it definitely goes a lot harder than it did stock...not too concerned about the numbers
Yeah most of the time we see accurate HP numbers just the torque is wrong so you still picked up a good 70-75awhp over stock! That's more than 50%! I think it should drive much better :)
@scottryana A 1HD-T lays down about 75-80 RWKW stock apparently, so if the current power output is anywhere near the money, I'm very happy...and the fuel pump is nowhere near maxed out...:hmm:
