Howdy
USA
Engine Tem
If I want to check if my water temp gage is ready correct on my dash can I double check somehow? I have a direct temp laser could I shoot the engine block with that?
What temp would you expect I should read after running engine
Your thermostat housing should read within about 10 degrees F of the thermostat rating. The stock thermostat is 190 degrees, if I remember correctly.
The sensor for the temp gauge is towards the back of the block on the driver's side, on a 2F engine. It is usually going to read higher than the thermostat temperature because of heat soak from the head.
Engine Tem
The gauge doesn't have numbers on it, so exactly what are you checking?
