Hi folks,
My AT shift knob had worn & cracked leather so I took a slight gamble and bought an 80-series vinyl knob to test, P/N 33542-20150-C0. Turns out it works perfectly if you're willing to ditch your leather. The knob is a cushy vinyl and feels great to me. It looks 100x better too.
Worn leather vs. new vinyl:
Side-by-side comparison:
The tools you'll need:
- Phillips head screwdriver
- Small flathead screwdriver
- Long pointy metal pick
The steps to DIY:
1. Buy new knob, it's around $85, P/N 33542-20150-C0
2. Remove shifter console bezel:
- Unscrew transfer case knob.
- Move AT shift lever to N (I did it via the shift release button under the small cover so my key wouldn't have to remain in the ignition while working, possibly draining battery)
- Grab inside the cup holder and pull up hard. There are two pressure clips directly under each cup holder, once they release the rest of the bezel will rise up.
- Unplug the seat heater and PWR/2ND switches.
- Lift off bezel and set aside.
3. Remove two phillips screws on front of shift knob. Careful not to drop them into the bowels of the console.
4. Release O/D harness from plastic clip on rear of shifter housing (below left), and release the connector on the passenger side by gently prying up retention tab with small flathead screwdriver (below right). Unplug the connector from its mate.
The steps to DIY:
