Honda Accord head gasket
morganism
SunkCostFallacy
Verde Valley, AZ
2002 4cyl 2.3
Burning water, but oil is clean. Overheated couple times last 2 weeks. Melted the overflow tank 2 months ago.
head gasket, or crate engine?
recommend gasket? Mahle is avail, but not complete set in kit. I dont see any avail with copper beads on the edges
Just read that i shouldn't do valve job, as the raised compression blows the rings loose, and increases oil consumption. Its at a quart a month right now
2002 4cyl 2.3
Long block time unfortunately
the first time it got hot you were ok with a head gasket.
that time has passed.
find a running car and pull the motor, swap it in.
If yours is like all the other 02 Honda’s it’s got almost 300k and isn’t worth a new motor. So keep it cheap, pull a running motor and do nothing but put it in and enjoy it for the next 20-30k
I have done lots of short and long blocks in my time and that includes head gaskets. I would side with rhah just eliminate the potential risk and go with a running long block. Do both a static and dynamic compression test. Test the oil pressure if that is possible.
