RockCrawler.com High strength birfields and axle shafts for toyota applications (1 Viewer)
Toyota Trucks & Landcruisers are well known for their strength & reliability all over the world.* Out of the box they feature some pretty great drivetrain, but they do have their limits.* *The factory axles are 30 spline at the diff, but neck down to 27 spline at the birfield creating a failure point.* Additionally [...]
Toyota Trucks & Landcruisers are well known for their strength & reliability all over the world.* Out of the box they feature some pretty great drivetrain, but they do have their limits.* *The factory axles are 30 spline at the diff, but neck down to 27 spline at the birfield creating a failure point.* Additionally the factory Birfield joints are not built to withstand the added stress of larger tires and heavy offroad use.Nitro Gear & Axle has addressed this by offering a range of Heavy Duty Chromoly Birfield Joints & Axle Shafts.
-NITRO 30/30 Kits feature axles that have 30 splines at both ends, eliminating the factory neck-down.* Fully compatible with factory or aftermarket carriers, lockers, & hubs.
-High strength Chromoly Material featuring State of the art machining, heat-treating and polishing processes for uniformity and ultimate in stenght.
-Wide application range suiting most Toyota pickups, 4runners & Land Cruisers
Complete Chromoly 30/30 Birfield & Axle kit Applications:
(All kits include inner axles that have 30 splines at both ends, birfield joints for both sides)
FJ80 KIT IS 30/BIG24
AX TBIRF-30-KIT 79-85 PICKUP & 4RUNNER W/ SOLID AXLE 30/30 SPLINE (BOTH SIDES)
AX TBIRF-FJ40KIT 76 & UP LANDCRUISER FJ40 30/30 SPLINE (BOTH SIDES)
AX TBIRF-FJ60KIT 81-90 LANDCRUISER FJ60/62 30/30 SPLINE (BOTH SIDES)
AX TBIRF-FJ80KIT 91-97 LANDCRUISER FJ80, FZJ80 (BOTH SIDES)
Individual Birfield joints
Featuring replacement spline configuration to fit stock joints/axles)
AX TBIRF-HD PICKUP, 4RUNNER, LANDCRUISER FJ40/55/60/62, LJ70 (HD JOINT)
AX TBIRF-FJ80 91-97 LANDCRUISER FJ80, FZJ80 (REPLACEMENT JOINT)
AX TBIRF-FJ80HD 91-97 LANDCRUISER FJ80, FZJ80 (CHROMOLY/300M HD JOINT)
Individual Axles, and more also available.
WWW.NITRO-GEAR.COM
info@nitro-gear.com
Available through:
JTS PARTS & ACCESSORIES www.justdifferentials.com
509.888.2953 info@justdifferentials.com
Link
