Just got inventoried
1994 Toyota Land Cruiser
Build Date: 07/94 / VIN: JT3DJ81W5R0080719
Exterior Color: Dark Emerald Pearl / Color Code: 6M1
Interior: Gray Leather / Trim Code: LB10
Mileage: 284,302
Stock # R0080719
All parts come with a 60-Day Warranty.
Call, Text, Or Message us at 314-502-3104
Mileage: 284,302
Stock # R0080719
- Engine Assembly W/O Harness (4.5L 1FZ-FE) - $3000.00
- Engine Harness - $300.00
- Engine Computer (89661-60221) - $550.00
- Transmission W Transfer Case - $700.00
- Rear Driveshaft - $125.00
- Front & Rear E-Locker Swap (4.10 Ratio, E-Lockers, Complete Axles, With Control Module, Switch, Front Diff Harness And Rear Diff Sub Harness) - $4500.00
- Headlight (Driver) - $300.00
- Front Corner Light (Driver) - $125.00
- Turn Signal Light - $50.00 ea
- Upper Grille - $135.00
- Fender W/O Flare (Driver) - $225.00
- Inner Fender- $275.00 ea.
- Fender Flare Front (Driver) - $200.00 / Rear Flare (Pass, Cracked & Rough) - $100.00
- Hood (Some Rust, Several Dents) - $125.00
- Front Door W/O Panel or Mirror - $200.00 ea
- Rear Door W/O Panel or Flare - $150.00 ea
- Sunroof Glass - $350.00
- Sunroof Motor - $150.00
- Rear Quarter Window Glass - $150.00 ea
- Fuel Tank Door - $40.00
- Rear Lower Hatch W/O Carpet (Minor Dings) - $200.00 / Upper (Several Dings, Minor Rust Forming) W/O Wind Deflector or Third Brake Light - $200.00
- Third Brake Light - $175.00
- Wind Deflector W Brackets - $300.00
- Rear Bumper W/O End Caps - $150.00
- Rear Bumper End Caps Driver - Damaged / Passenger - $165.00
- Seat Control Switch - $175.00 ea.
- Seat Tracks W/O Switch (For Parts, Forward/Reverse Inop) - $125.00 ea.
- Climate Control - $200.00
- Transmission Control Module (P/N 89530-60080) - $175.00
- 4 Wheel Drive Control Module (P/N 89533-60030) - $125.00
- ABS Pump & Module (P/N 44510-60010) - $250.00
- Lower Hatch/Tailgate Carpet - $150.00
- Wiper Cowl - $150.00
- Wiper Motor (P/N 85110-60141) - $135.00
- Fuel Pump - $300.00
- Fuel Tank - $325.00
- Air Cleaner Assembly - $100.00
- Air Flow Meter (AFM) - $275.00
- Roof Rack W/Cross Bars - $250.00
