Have you guys seen these? (2018 Mahindra ROXOR)
Northeast Georgia (Habersham)
I got an email from Coleman Powersports. I had talked to the service department a while back about these and they finally got them in. I wouldn't dish out $15k for one, but I also wouldn't pay that much for a Razor. Anyway, I think it's cool they are adding more to that category of vehicles. I wonder how they will hold up? It seems like a diesel Willys Jeep.
A perfect blend of old school simplicity and current technology. Invest in an industrial strength ROXOR today and be prepared for the fun of accessorizing and customizing to match your adventure. This simple platform has proven itself worthy. Make yours MISSION: READY.
Features
  • Reliable, economical, and long lasting, 4-cylinder turbo-diesel engine
  • 4WD to help get you where you need to go...anytime, anywhere
  • Sturdy box steel frame
  • Rock solid reliable drivetrain with automotive style 5-speed manual transmission
  • Big wheels and brakes, high tech tires
Dimensions & Capacities
  • Wheelbase: 96 in.
  • Base Curb Weight: 3035 lb.
  • Length: 148 in.
  • Width: 62 in.
  • Height: 75 in.
  • Ground Clearance: 9 in.
  • Fuel Capacity: 12 gal.
  • Rear Payload Capacity: 349 lb.
  • Towing Capacity: 3490 lb.
  • Person Capacity: 2
Engine
  • Type: Turbo Diesel m2DiCR
  • Cylinders: 4 - 4 Stroke Compression Ignition
  • Displacement: 2.5L / 152 cu. In.
  • Bore & Stroke: 88.9 x 101.6mm
  • Power: 62 HP @ 3200 rpm
  • Torque: 144 ft lbs @ 1400-2200 rpm
  • Compression Ratio: 18.6 : 1
  • Cooling System: Liquid
  • Fuel System: Direct Injection
Drivetrain
  • Transmission: 5-Speed manual
  • Transfer Case: 2-Speed manual
  • Driveline: 2WD/4WD
  • Full Floating Front Axle: 3.73 : 1
  • Semi Floating Rear Axle: 3.73 : 1
Chassis & Suspension
  • Chassis Type: Box Steel Frame
  • Front Suspension: Rigid Leaf Spring w/Stabilizer Bar
  • Rear Suspension: Leaf Spring w/Shock Absorbers
  • Shock Absorbers: Double Acting Hydraulic
Brakes
  • Dual Hydraulic Vac Assist: Standard
  • Parking Brake: Standard
  • Front Brakes: 9 in. Disc
  • Rear Brakes: 11 in. Drum
Additional Features
  • Steering: Hydraulic Power
  • Instrumentation: Single Gauge
  • Lighting / Headlights: Halogen
  • Battery: 72Ah / 12v
  • Alternator: 45 to 90 Amps
  • Power Port: 12v STD
  • Storage: 2 seat boxes
  • Seating: 2
  • Tires: 235 / 70R16
  • Wheels/ Steel: 16 in. - 5 x 5.5 lug
  • Wheels/ Alum.(Optional): 16 in. - 5 x 5.5 lug
Colors
  • Carbon Black: Urethane
  • Classic White: Urethane
  • Fire Orange: Urethane
  • Tahoe Blue: Urethane
Performance
  • Max Speed: 45 MPH
  • Max Towing Speed: 15 MPH
Other
  • Country of Assembly: USA
NOTES:
While every effort is made to produce up-to-date information, specifications and accessories may change. Your authorized dealer can confirm materials, accessories and equipment availability prior to purchase, as well as all up to date pricing information. We reserve the right to change, modify, or cancel specifications, designs, features, and colors, without notice or obligation. Some differences between the manufactured product and the descriptions and/or specifications may exist.Specs
2018 Mahindra ROXOR for sale in Falls Church, VA. Coleman PowerSports
I think it's awesome Mahindra decided to bring this to market. If the off road aftermarket gets in to them anywhere near as much as they've jumped in to side by sides this is going to be a huge hit. The stock roll cage looks a little dinky though. Not much triangulation.
I thought the same on all of the above.
I spoke to the Mahindra dealer here in Warrenton and the said the dealer education on them has been almost Nil with no spec sheets no education and no estimated delivery times at all.
