Media GX470 Wheel/Tire/Lift Picture Combination Thread
Photo/Video/Audio threads
I'm considering these Method 305NV in bronze inspired by this member's post (mainly because they look great and he also didn't have to do any spacers or body chopping). The options on DiscountTire for off-set are 0 or 25...I'd want zero right? Would this setup mess with anything long term or require any additions to keep things running smoothly? Also, do bead lock wheels add any additional things to consider as far as maintenance or headaches? Thanks!
Those are dope and yes you should be fine with no BMC running a 0 offset. Those are simulated bead lock's with a special lip to seat the bead better when running low tire pressures. This probably does preform better than a standard style lip but it's not a "true beadlock" where each of those bolts actually comes in contact with the tire bead, physically locking it in place.
METHOD TRUE BEAD LOCK RIMS
The biggest issue with those 305's and true beadlocks in general, would probably be one of the bolts falling out and having to replace it. If this does happen it should not effect performance at all on the 305's, it will probably just bug you, but TBH not even sure if those bolts in the 305's have actual threads! The bolts may be mounted in place permanently, not sure.
On a true beadlock it's less ideal to lose a bolt but missing one bolt wont kill you, though I'd say you'd want to replace it for safety's sake. With true beadlocks you need to periodically check all the bolts on the wheels to make sure they aren't coming loose. I had to do that with the TRD rock warrior rims on my FJ, not beadlocks but same concept of having to check the bolts on the rims regularly. I was missing a few bolts on the rock rings on each wheel and it was fine...annoying though! Even though I would check them regularly to make sure they weren't coming loose...there were always a few that needed attention.
A lot of people seem to like these 305's and have good success w/ them, so you probably will too!
Front: 2.5 Radflo C/Os set to about 2.7" lift; Eibach 700lb springs.
Rear: Radflo 2.5 shocks; Toytec 3" HD springs - Looking to swap to ~2" lift springs
Wheels: FN Overland Spec B; 17x8.5; 0 offset - May swap to something not black...
Tires: 34x10.5/17 BFG KO2 - Next size will be 285/75
Any lift here?
Roughly 2" front and rear, she does look pretty low though. I need to find some stock height measurements to compare too. She's so heavy that I struggle getting it lifted. I really need custom built coilovers
Pardon the "driveway" shot but I haven't had a chance to get the rig out since the wheel upgrade.
2" lift on Eibach Pro Truck kit
Level 8 MK6's: 17x8.5, -10 offset
Wildpeaks in 265/70/17
Things may have gotten out of hand :P
Now on Alpha Beadlocks and 37x12.50R17 Fury RTs with allllll the stuff to run 37s well.
Finally decided on my wheels and got em on today. (Thanks to everyone for their contributions and advice, this forum has become my new homepage, great community to be a part of!)
Went with these DX4 Nitros in bronze. Unsure of the offset but there is (now) a little front fender rubbing in full lock.
2006 GX470
Ironman 4x4 Nitro Gas 2.5" front and rear
Ironman 4x4 UCAs
DX4 Nitro bronze wheels
BFG KO2's 33's (285/70/17)
Victory 4x4 roof rack
Amazon special bull bar/pod lights
Custom fab foldable sleeping platform
(awaiting on NashFabCo rear ladder, Bison Gear rear window panels)
Wheels: Stock 17"
Tires: BFG K02 275/70/17 tires
Spacers: 1.25"
Lift: 2"
Hello I'm new here :) but I've been in a GX470 relationship for 12 years and I'm very happy.
I have such a question as you can see in the picture
Lift the front side by 2 inches
rear airbag trick 2 "
And install BGKO2 275/65/R17
2 "Lift is enough? To 285/70/R17 Tire or 2.5 "inch should I lift?
@dajobo tires are 285/70-17. Stamped on the side of the tire. Looks great though! How do you like those milestar tires? I’ve heard good things about them
You mean those are not really 35.5x11.5 tires ?
I have buddies who both ran them on their 80s in 35x12.5 16r size and they had bad irregular wear and bubbling/warping issues but they ran them anyway for a few years. They were also very loud towards the end of their life - they switched to Toyo Open Country MT's and said they wouldn't look back - I also run the Toyo MT's - great tires, even for east coast winter driving - no complaints!
