great trailer axle
  • Thread starter Thread starter willysworker
  • Start date Start date
willysworker
I built a trailer and found a Dodge Grand caravan rear axle was just right. flipped it upside down.
Great idea. A good use for a crappy vehicle.
thanks for the idea, bet you could get one cheap too
YEP! The local Pull & Save always has a dozen Caravans in the yard. Drum to drum including the leave springs and bolt on mounts $58.
I like that idea too...could you post more pics of the whole set up and measurements....
Thanks
Looks like a great trailer axel!
2 questions , do you think there will be any camber/caster issue?
It look like the entire weight is on the U bolt holes , do you think the threads are strong enough and is the load bering material thick/strong enough where the U bolt is?
Thanks ,
ken
Thanks ,
ken
The FJ 40 has been a spring under vehicle for years much more weight than you would normally load a trailer.
Ya,
But isnt the weight supported by a U bolt going around/on top of the axel tube?
ken
Ya,
ken
All the weight is still on the threads regardless.
Ok , but there is still a load issue, on the bolt boss.
Since there is no U bolt that is transferring load over the axel housing you get all the load to the thickness of material that the bolt is hanging on.
ken
Looks like a set of square type u-bolts could be used if there is concern about the axle's mounting flange not being strong enough. Straddle the axle and poke them thru the flange's holes.
Camber should not be an issue,, caravans are set up with a very neutral camber.. Should have almost zero and they can be aligned if out,, A decent amount of camber is allowable on a trailer.. but if you put enough weight on one of these to see the camber change you should get a heavier axle..
How much weight can one of these axle hold? I like the idea, but would be concerned with durability.
The caravans they came on weighed close to 4k# and were rated to tow3500# I think? should handle a 2k# adv trailer,, but I'd love to put one thru the torture test.. small trailer axle flipped and way too much weight on washboard roads,, just to see the carnage..
