GP25 Propane Truck Lift Idling Issues
Status
Not open for further replies.
Truck runs fine but after a few secs of idling it runs out of fuel. Ive checked the fuel coming from tank to regulator and converter and is okay. I did have a failed air filter and some dirt was sucked into the intake system. Did compression test on engine and is okay. Any help would be greatly appreciated. Thanks.
did you check the filter in the regulator? edit, [please turn the propane tank valve to the of position before you do this, a purge the fuel line slowly].
are you using a mixer or carb with an adapter plate?
do you have priming solenoid on the vaporizer?
Status
