Gearing and Wheel Question...
Hi I am a newbie here and have a question on my truck...
I have a 1999 tacoma 4x4 ext cab 2.7L that came with the steel wheels and the smaller tires (225). I need to replace the tires and have an opportunity to get a fairly (very fairly) new set of american racing wheels with 31x12.5x15 with pro comp Mud terrains on them...for the price of a new set of "just tires". My sticker says its geared as a B02...will these boog my truck down too much...will I notice the difference is speed and mpg? I would like to lift it 3" this summer.
Thanks to anyone that can help.
tpan
According to the B (8" ring gear) 02 (3.58:1), you will have a dog. You will notice loss of power and mpg drop. So at this juncture you have two options. Spend the dough to get it regeared, or get the bigger tires and live with the guttless gasper.
Usually you can find stock 4.10s, on ttora. Hell, I even have a set for the rear. But you need to double check with your axle code gear ratio..
Axle Code Gear Ratio
RZN140L-TRMDKAB 3.416
RZN140L-TRMDKAB 3.583 2001
RZN140L-TRPDKAB 3.727 2001
RZN140L-TRSDKAB 3.583
RZN150L-CRMDKAB 3.416
RZN150L-CRMDKAB 3.583 2001
RZN150L-CRPDKAB 3.727 2001
RZN150L-CRSDKAB 3.583
RZN161L-TRMDKAB 3.583
RZN161L-TRMDKAB 4.100 With 10.5R 15 Tire, 7JJ Wheel 1997-98
RZN161L-TRMDKAB 4.100 With 31x10.5R 15 or P265/75R 15 tire 1999
RZN161L-TRMDKAB 3.909 2000
RZN161L-TRMDKAB 4.300 With 31x10.5R 15 or P265/75R 15 tire 2000
RZN161L-TRPDKAB 4.100
RZN161L-TRPDKAB 4.555 With 10.5R 15 Tire, 7JJ Wheel 1997-98
RZN161L-TRPDKAB 4.555 With 31x10.5R 15 or P265/75R 15 tire 1999-2000
RZN171L-CRMDKAB 3.583 1997-1999
RZN171L-CRMDKAB 4.100 With 10.5R 15 Tire, 7JJ Wheel 1997-98
RZN171L-CRMDKAB 4.100 With 31x10.5R 15 or P265/75R 15 tire 1999
RZN171L-CRMDKAB 3.909 2000
RZN171L-CRMDKAB 4.300 With 31x10.5R 15 or P265/75R 15 tire 2000
RZN171L-CRPDKAB 4.100
RZN171L-CRPDKAB 4.555 With 10.5R 15 Tire, 7JJ Wheel 1997-98
RZN171L-CRPDKAB 4.555 With 31x10.5R 15 or P265/75R 15 tire 1999-2000
RZN191L-TRPDKAB 3.909
RZN191L-TRPDKAB 4.300 With 31x10.5R 15 or P265/75R 15 tire
RZN196L-CRPDKAB 3.909
RZN196L-CRPDKAB 4.300 With 31x10.5R 15 or P265/75R 15 tire
RZN196L-CRPDKAB 4.100
RZN196L-CRPDKAB 4.555 With 31x10.5R 15 or P265/75R 15 tire
VZN150L-CRMDKAB 3.153
VZN150L-CRSDKAB 3.153 1997-98 & 2000, 3.583 1999
VZN150L-CRSDKAB 4.100 With 31x10.5R 15 or P265/75R 15 tire
VZN160L-TRMDKAB 3.909
VZN160L-TRPDKAB 4.100 With 10.5R 15 Tire, 7JJ Wheel
VZN170L-CRMDKAB 3.909
VZN170L-CRMDKAB 4.100 With 10.5R 15 Tire, 7JJ Wheel
VZN170L-CRMGKAB 3.909
VZN170L-CRMGKAB 4.100 With 10.5R 15 Tire, 7JJ Wheel
VZN170L-CRPDKAB 3.909
VZN170L-CRPDKAB 4.100 With 10.5R 15 Tire, 7JJ Wheel
VZN170L-CRPGKAB 3.909
VZN170L-CRPGKAB 4.100 With 10.5R 15 Tire, 7JJ Wheel
VZN195L-CRPDKAB 3.909
VZN195L-CRPDKAB 4.100 With 31x10.5R 15 or P265/75R 15 tire
gears
coincidently your post would be applicable to 90 series as well (same diffs). What size tire do you intend to run?
You posted on the 90 series Land Cruiser Prado forum. I've moved your thread to the right forum, you'll get better help here.
