This past weekend I had the 200 at about 5000 ft in 95 degree weather and had the boiling fuel issue. Seems to be the norm, I guess....
My thoughts are i would love a guinea pig to pave the way!Circling back to this regarding a potential in-line fuel cooler - my spare doesn't fit underneath anymore so there's room for activities. Where the return line connects to the tank it's a quick connect fitting. Theory would be go quick-connect to AN-8, run stainless braided to a Setrab cooler (FP119M22I) mounted above the rear frame rail near the charcoal canister, then return with an AN-8 to quick connect adapter so it plugs back into the stock connector. In theory it's plug and play, and doesn't require any butchering on the stock system. Thoughts?
forum.ih8mud.com
So does this mean that Budbuilt or Victory skids may contribute more to this since they aren’t ”vented” vs Dissent or Slee which have cutouts around the cats?
If you wait long enough, you will be able to fill it.I am in Wyomkng only at 5000 ft, gas from a Mobil in South Dakota, don't think I overfilled (but don't know for sure). I have an LRA 12.5, and full Budbuilt skids. We've driven 2000 miles in the last several days (over 3000 in the last three weeks), on and off road and didn't have any fill issues. The last few days have been 95-101 Fahrenheit, and I can only imagine how hot things are getting behind the skids. We stopped for gas near Devil's tower and gas cap was under a lot of pressure. I slowly opened it to vent the pressure, and when I finally popped the cork, I think a tiny amount of fuel came out. I could see the vapors venting out the cap, and couldn't put any gas in the factory tank, The pump just kept shutting off every time I tried.
I transferred from my aux tank to get me to a campground, hoping that things might be better after the system cools overnight.
I've driven a ton of dusty stuff in the last couple of weeks, so I'll check my prefilter and K&N vent filter on the LRA this morning. I did replace my engine air and cabin filters before this trip and they were in bad shape, I forgot to check the LRA vent. Hopefully it is as easy as this...
Then we'll be off to try to fill the tank again. Fingers crossed that we can fill the tank - we have a lot more ground to cover in the next two weeks (including LCDC).
If engine air filter is getting clogged, it creates a rich fuel condition. ECM works to correct to a 14: 1 mix. A rich condition will drop cylinder head temp. So I doubt air filtration part of your issue.I am in Wyomkng only at 5000 ft, gas from a Mobil in South Dakota, don't think I overfilled (but don't know for sure). I have an LRA 12.5, and full Budbuilt skids. We've driven 2000 miles in the last several days (over 3000 in the last three weeks), on and off road and didn't have any fill issues. The last few days have been 95-101 Fahrenheit, and I can only imagine how hot things are getting behind the skids. We stopped for gas near Devil's tower and gas cap was under a lot of pressure. I slowly opened it to vent the pressure, and when I finally popped the cork, I think a tiny amount of fuel came out. I could see the vapors venting out the cap, and couldn't put any gas in the factory tank, The pump just kept shutting off every time I tried.
forum.ih8mud.com
Thanks, that is really helpful info. I appreciate it.If you wait long enough, you will be able to fill it.
The process of boiling takes thermal energy out of the fuel, that’s kind of the point. In your case it means it may take a half hour or something but eventually it will calm down and you could add more to the tank. Not to mention any fresh fuel added, even slowly, cools the whole thing down to reduce vapor production.
Also getting to the fill station when the fuel hasn’t heated up yet or has had a chance to sit and cool would help.. like grabbing breakfast at a nearby restaurant or something then going to fill..
This surely sounds annoying but I think you’ll get it figured out easily.
This probably doesn't help the situation (after removing the splash shield) - that's a dirtbike prefilter over my LRA vent.
And the filter itself before and after:
View attachment 3066714View attachment 3066715
It was touched on in another thread, but using low range off-road is going to help overall cooling. Keeps the engine driven fan pushing more air, coolant circulating faster, transmission and torque converter temps lower.
It may help engine temperature, but the lower vehicle speeds will also lead to less air flowing around the gas tank, which might lead the fuel to not cool fast enough as the hot return fuel keeps getting dumped in.
There definitely seems to be a lot of inputs into the equation that affect how the problem presents itself.
