Let's be clear: I'm not saying cleaning radiator fins will cure all fuel boiling. But
we must make sure basic are in line first.
Or we chase out tails. Also worth a note: Once a fuel boiling episode has happened, it become harder to cure to 100 % to no boiling events. It's believed that EVAP become damaged, is one possible reason for this.
I can't speak for the 200 series, as much as I can for 100 series. As most of my coolant work and monitoring has been on the 100 series. I just don't work on enough 200 series to get the data points needed, like
@Taco2Cruiser did. And most of the 200 I do service, are daily drivers. Most coolant work I do on 200's is; PM radiators replacement, cap & hoses, water pump, thermostat and flushing. Even though I replace the rads, I still wash the other 2 radiators fins, that are in front of engine rad. But still the principle applies to all vehicle. Coolant system need to be keep at peak performance!
First in that all radiator fins become clogged. Once debris builds in them, a few things happen:
First air passages through fins are obstructed, reducing air flow. It is air flow over radiators fins and core tubes, that carries away heat.
Second the debris will cause some extra heat retention. As the ECT goes up, fuel in rails and fuel lines which includes return lines wrapping around engine intake manifold heat-up more than designed for. The hotter the engine is running (ECT is our measure of this) the more heat fuel lines absorb.
A secondary effect, is AT fluid does not cool as well. It also has it's own radiator (fins clog) and a pre-cooler in engine radiator. This than raises AT fluid temp. Which the 200 series AT fluid (in new, or normal) run closer to ~190F, whereas 100 series run ~155F. The 100 series with mildly obscured radiators. AT temp reach around 190F when pushing it on HWY at 80 MPH gearing down to run in high RPM of 5,400 (red line). Take that same 100 and clean radiator fins. AT run around 165F in same HWY high RPM run.
As secondary effect is : Fuel molecules expand as the fuel heats. This reduce fuel volume, which can lead to a lean fuel condition. It works ECM harder, and tends to run engine on the lean side. Lean fuel mixture, raises cylinder head temp. Which in turn raises ECT and CAT temp. We do see a drop in CAT temps after radiator fins clean and driven under same condition. Cooling fuel has opposite effect. As a teenager, I had some buddies raced full stock GTO in the early 70's. They had hidden tricks to increase HP. One was a coffee can with a copper tube coiled in it. The tube was hooked in fuel delivery (inline) line. They'd fill coffee can with ice, just before the race. This would shrink fuel molecules as such delivery more fuel to intake ports.
Another effect of hot fuel is heat transfer to pump. Heat increase electrical resistance, and this can slow pump, reduce fuel flow.
I just bough very clean 07LX w/145K out of ABQ NW last month. In studying it's service history as a pre inspection, before hands on inspection. I saw Lexus service history notation of hesitation while driving at times, as reported by customer. Dealership shop could not duplicate. The time of year was summer. So I assumed radiator fins clogged..
In test driving around ABQ. ECT would jump to near 200F as I'd wait at a red light in full sun OAT 94F, AC off. If AC turned on, ECT would go over 205F. This is one of the best indicator fins are clogged and or some other issue with coolant system.
In divining back from ABQ to Den. I was hitting ECT of 214F at OAT 91F overcast 6PM at 5,400 RPM (red line) ~80 MPH. AT 2 temp was hitting ~193F. AT temp in 100 series should stay around 145F to 167F. ECT should stay below 200F in 03-07 and below 190F in 98-02. So this was running hot!
Once back in Denver, first thing I did was look at radiator fins and clean them. ECT and AT fluid temps dropped as soon as I did. But like any radiator not regularly cleaned, it needs more cleaning. We're only about 60% effective at clean, with rad in place. Even radiators removed and cleaned, it's very difficult to get 100% clean and takes repeated washings.
The service history, carfax and condition of vehicle, indicates it's been 98% driven on paved roads. In South Colorado and north NM/AZ
Here's what I'd call mild debris in engine radiator fins, in my new 07LX w/145K miles.
I see much worst on a daily basis. I sometime get two or three shovels full, not including what washed down the gutter, come out of radiators fins!
I'll repeat for emphasis: Let's be clear: I'm not saying cleaning radiator fins will cure all fuel boiling. But
Or we chase out tails. Also worth noting: Once a fuel boiling episode has happened, it become harder to cure to 100 % no boiling. It's believed that EVAP become damaged, is one possible reason for this.
Gauges on dash is useless especially in LC 100 series, the LX seem slightly more responsive. But neither move much, unless hitting ECT over ~240F, than still not much until overheating event. If you see a dash gauge peg HOT, your in trouble.
I use a Bluedrive and just picked up a OBDIImx+ this year. I read the ECM?CUP data from my iphone from all sensors. Which OBDmx+ app I use, allows AT temps also. These give actual read outs of data from CPU/ECM continuously. They also keep logs on my iphone, which I email myself. So I can study varying condition on long or short runs.
Here a snap shot of log, from my trip ABQ to Den, just at end of running hard HWt burn. What I call a HWY burn (AKA Italian burn, AKA Italian tune). I do these HWY burns to cook clean CAT s, A/f & o2 sensors and blow off some cylinder head carbon. See ECT at 213.8F, gauge on dash never moved from 187 to the 213.8F. But I can assure you, that over 200F is not normal. Even in stop and go high noon sun 100F OAT in the mile high city.
But clogged radiator fins are not only coolant issues I find. But they are in most every rig I inspect.
Here are some more issues I find with coolant systems:
- Bad rad cap. Cap is designed to release pressure at 108Kpa. If it stick pressure in coolant system increase and so doe ECT temp.
- Bad thermostat or installed wrong or junk aftermarket. 200 series thermostats come in a water inlet housing, so really hard to install wrong. But 100 series have a jiggle valve, which must be at top. If not air will not properly purge to high point of coolant system.
- Reservoir issues. The 200 series reservoir was redesigned. In the 100 series, I find 1 in 4 feed tube cured up. This than suck in air during cool down
- Reservoir lines clogged.
- Low coolant in system. We look at reservoir and see fluid sat think all is good. Wrong. We must check under radiator cap. Again more of issue in 100 series. But if air in any coolant system, it will not work properly. Than we often get false reading, by just looking at reservoir.
- Wrong mix of coolant. This is never an issue in 04-up if using Toyota pink SLL pre mix 50/50. But some feel they can run 100% red Toy LL to improve cooling or lower freezing temp.... Wrong. Stick with Toy coolant and mix only as stated on container, is best. Flush often!
- Weak fan clutch.
- Coolant leaks.
Vacuum leaks & fuel starvation, plugs, coils, PCV, T-body and MAF cleaning, etc. Are a issue themselves, that must be brought inline. Transmission flush and with what. All need brought inline with factory design.
I can assure you. I find a lot of 2UZ-fe running hot. In most every case I hear my engine runs fine, no issues. They're wrong 8 out 10 times! but the 2UZ can take a licking and just keep ticking. It is legendary.
@Taco2Cruiser mention how much corrective work he does, where others have touch with a wrench. I too do more corrective work than you can imagine. From shop you'd not believe. Many are very well known in mud, as a great shops. I have stuff brought to me daily to correct F--ups. Coolant system is just one system I do a lot of correcting on.
In all cases, get basic inline!
But what we can not control is the weather. Hot is hot and high altitude has it's effects. That is where fuel cooler is a great idea, Rob! Let me know what you come up with. I'll use anything you design.
