Just discovered my 11 year old KeepRite DC90 furnace has a very noisy (squealing) "combustion draft blower" ... as it is starting up for the new cold season. I had noticed water on the shelf (also leaking to floor) under the blower last year but ignored it. I thought the drain from the furnace had plugged but their was no apparent obstruction. Now I see water again and what sounds like a bearing shot in the blower where the water seems to originate.
An online search for this problem and model finds several different sources pointing to a faulty heat exchanger and warns of CO danger. Something about "popped ring" . Not sure how these symptoms correlate though.
Anyway I sent a note to KeepRite head office and get a fairly standard response regarding warranty and the need to contact a qualified service facility (no argument there!) BUT also this comment:
"Further, this unit is designed under a negative pressure therefore making it impossible for CO to enter the air stream of your home"
Is this true?? Is this BS? What does it mean "designed under a negative pressure..."??
Should I swap this out for a Trane?? I am now worried that the negative pressure they are talking about might be the vacuum between the ears of the guys who support this product ....BUT admittedly I am NOT an expert ... just looking for some guidance.
Thanks!!
PS - when I put a level on the furnace it does slope away from the drain side of the unit fwiw
Thanks!!
