Trade fs/ft overland built tacoma
Up for sale is my 99 TRD Tacoma that I built for overlanding. I'm the third owner in this truck it was babied and garage kept/Dealer service until I bought it. almost everything that has been replaced was OEM factory parts and done as preventative maintenance. The gentleman that I purchased it off of used it to commute to work (freeway miles). Gradually I have built this up to a very capable and reliable off road truck,I wouldn't hesitate to drive it across the US and it has been in many states.
The only trades im looking for would be a double cab tacoma or 100 series land cruiser
All maintenance is up to date including timing belt, water pump,belts,and idler bearings with OEM. Truck is done and needs nothing!
Engine-*3.4 5vzfe 189,xxx * PowerAid throttle body spacer *ARB Safari snorkel *Full synthetic oil * New radiator * Red top Optima * New rear main seal * Magnaflow muffler * Rebuilt starter with OEM parts
Transmission/transfer case-*5spd manual * Marlin heavy duty clutch * new slave cylinder * inchworm dual case adapter * Marlin turbo 23 spline 4.7 xd gears mated to stock transfercase *4xinnovations polyurethane transmission mount *m.c. heavy duty detent springs * new carrier bearing and shortened two piece drive line * front and rear drive lines are interchangeable in case one fails
Front axle-*Rebuilt 4 cylinder manual hub conversion w/ OEM shafts and one spare * new wheel bearings and seals *Brand new reman tundra 231mm brakes and ceramic pads *OEM roters *Nitro 4.88 gears (open) *sanoran steel TRD Progressive rate coil overs with bilstien shocks *moog upper and lower ball joints *moog inner tierods * Energy Suspension polyurthane rack and pinion bushings *1" diff drop
Rear axle-* stock e-locker diff with nitro 4.88 gears *bilstien 10" travel shocks *yukon chromoly axles *m.c japanese wheel bearings and eco seals *stainless steel *brake line * stock springs with heavy-duty add-a-leaf kit * frame plating * All Pro u-bolt flip kit
Bumpers-*ARB front with 20"led LED bar *2 kc lights *warn xd9000 winch with contractor box * rear bumper is custom made using 4x4 labs parts * swing out tire carrier with reverse lights * trail-gear rock sliders
Tires and wheels-* less than a hundred miles on a brand new set of Goodyear kevlar mt/r 285/75 r16 which are a true 33x11 on black aluminum rims
Bed has best top Softop With roll up sides and fold down if you need to carry something large
* Inside the bed has marine grade plywood storage drawer system. 3 cabinets with flat latches and to pull out drawers
Interiors clean and stock with the exception of wet Okole Seat Covers. Also has a CB and pioneer bluetooth mp3 CD player Truck has an ARB air compressor for airing up tires with ARB hose kit
$16,800 located in Northern California
Thank you for looking! And i can be reached at fjfowdie@gmail.com
Pics are here http://sacramento.craigslist.org/cto/4289194194.html
