I installed a Rough Country 6 inch lift about a week ago in my brand new 2008 FJ. Included in the kit were new spindles, which I swapped over my stock wheel bearings and hardware. After driving the truck for about a week (less than 150 miles) I discovered that I have play in the front hubs I can move the tire/hub assembly about a 1/8".....
When re-assembling the front axle shaft I used an impact wrench to tighten the 35 mm axle nut, rather than getting my torque wrench and setting the nut to factory specs.
Now that I found play in the front hub, is it possible that I just need to tighten the axle nut tighter? or did I wipe the hub bearings?
The truck has a total of 500 miles on thr odometer... I installed the lift kit last week and drove less than 150 miles...
I guess I'm asking is it possible that it would be normal to have play in the front hub bearings if the axle nut wasn't torqued enough?
