Well I've been hearing this noise for a little bit (even @ the summit) but it's now progressively gotten worse
I assumed it was the steering knuckle and just needed some grease but noooo we just took a look @ it and the noise is coming from my drivers side CV boot...did I bend something? Going to take a look @ it on monday up on a lift but just wondering if anyone has heard this before? sounds like really loud creaking, not good, it vibrates the entire vehicle through the floor board arghhhhhhh!!! hoping for the best but who knows
Any help would deeply be appreciated!!!! here is some info I found
Alright looks like I'm in need of a new CV arghhhh!!!! found this info right here!!
Constant Velocity Joints, Part 2: Service & Repair
A humming or growling noise. Sometimes due to inadequate lubrication in either the inner or outer CV joint, this symptom is more often due to worn or damaged wheel bearings, a bad intermediate shaft bearing on equal length halfshaft transaxles, or due to worn shaft bearings within the transmission.
My next question is what to do, I have a toyota resource through my work but will have to pay for the part @ cost, or do I put up a fit with the dealer and try to get it taken care of by warranty. as you all know I'm lifted with plenty of aftermarket parts installed. I'm a damn good debater also....should I put up a fight and do any of you have some good lines to tell the stealer? I swear this happened while not offroading also!!!!! HELP S.O.S!!!!!
