SOLD FL - Dakota Digital Guages VHX-62T-FJ
Fellsmere, FL
Selling my Dakota Digital gauges. They are working awesome but will not be needed in the next phase of my build, going to a tablet for my dash.
I forgot to take specific pics of this when the battery and motor were still installed but I will see what I can find and will put in the comments.
I made mini wiring harnesses for this, one for the wires coming from the motor and one for the wires from inside the cab. I had this on a shelf I made in the glove box and you run out of room quick in there and trying to screw all these wires in the control box while in the glove box is not fun. Now you can wire it up and plug it in to the harness.
I labeled all the wires and as you can see, the instruction books are included and you can also download these from DD.
I used the GPS speed sender with these and it works awesome. I am keeping the GPS sender and would highly recommended using that with these but you can get the sending unit for the transfer case from DD if you choose to go that route as well.
Bezel is included
Includes the DD dimmer knob, DD oil pressure sender, DD water temperature sender, cat 5 cable
I have the DD fuel sender as well if you need it. It’s been cut to fit the under seat FJ40 poly tank.
$650 plus shipping from 32948
Here is a screen shot from a video we did on Saturday. I have a dash cover to keep everything as clean as possible so it’s hard to see the gauges through it but..... they are there and working perfectly 🤣
