Ferkels Fantastic Voyage aka 99 miles to the new sty!
That new bearing looks like a 4 speed bearing...
Pic of mine...
SM465 for a tranny
Started in on the OP gasket today. Got derailed by some rain but not before I sprayed several layers of copper sealant on everything. Hoping to install tomorrow. 🐌 pace.
Is the copper supposed to dry over night?
progress n questions:
Got the pan gasket /flywheel on.
Next is replacing the TO bearing. I took the bearing off the housing but not sure of the bearing I received is the right one. The opening is clearly too big to fit snug on the housing. Its from RockAuto and says fits 72 fj55 3.9L... Also, Do I need new housing as I chipped a piece out of it housing removing the bearing? I did notice there's a plastic sleeve inside on the old bearing and am wondering if that is supposed to be used with the new bearing🤔
TIA for the help
View attachment 4035715View attachment 4035716View attachment 4035717
Here are a few rabbit holes on 3-spd and 4-spd bearings:
yep rabbit hole fo sho
ahh ok that's for a different trans.
The clutch disc is different (splines) but I think the T/O bearing is the same, it uses the stock carrier and fork and everything else
