- Thread starter
- #721
I had some high hopes for getting the rear main /clutch assembly on but caught a snag. small piece of the rear main got hung up....it'll have to wait. The good news? Halloween was fun!
Replacing the pan gasket is just about as much fun as dropping a Pig gas tank.Quick question: Is It is necessary to drop the oil pan /loosen the main bolts to get a new rear main seal in, or does the oiled up seal , then tapping in slowly technique work ? Some say take the pan off but I'm pretty confident that the pan gasket is good. That said
I damaged a seal the first I tried tapping it in so I'm not certain on this one...
After re-reading a few threads on this and speaking w/one of my consultants ( @Half Wacked aka Split Pea ) , I decided to do the right thing and replace the pan gasket too.
I would follow the FSM recommendation!OMG dropping the rear main cap makes getting the seal in a piece o cake, Do I need lock tight on those rear main bolts or just re-torque them?
Yeah I looked through the FSM and only found a sentence re the oil pan but am sure the main bearing has more detailI would follow the FSM recommendation!
Oilpan gasket? I did one not long ago, didn't look in the book except to get the oilpan bolt torque spec. Then I went to buy a little torque wrench.I think I have enough into to finish but would like to read the FSM version for this procedure.
Yes to all of those things. The one thing that differs is where to use the gasket sealer, on both sides of the bearing portions & on the ends and around the corners where the bolts are but some use a thin layer on both sides. throughout. With that thick of a cork gasket I would imagine just using it as I mentioned would likely be good. I'm using Toyota FIPG. One thing I added was chasing all the bolt holes and bolts to avoid any issues as I did find a few that were a bit sus. From looking at your old gasket ,Looks like you used sealant on both side yes?Oilpan gasket? I did one not long ago, didn't look in the book except to get the oilpan bolt torque spec. Then I went to buy a little torque wrench.
1) buy the one-piece oilpan gasket, not the 4-piece.
B) Clean both the oilpan and block surfaces very very well, take this opportunity to straighten any wavey parts of the oilpan lip where the bolts got over-torqued.
III) I used Copper Coat gasket sealer this time, worked pretty well. There are a couple dozen different ways to hold the oilpan up in the air while you thread the rest of the oilpan bolts in. I use 4 studs in the corners with nuts. This time I just snugged the oilpan up to the block and let the gasket sealer set overnight, didn't start torquing them down until the next day and the cork didn't squeeze out like it did last time.
Not my first time with this gasket but this time I took some care with the surface prep and torquing and it's pretty dry even 6 months later.
Oh yes, sealant both sides of the gasketLooks like you used sealant on both side yes?
Cool thx. Ill check it out!Oh yes, sealant both sides of the gasket
Edit: it just occured to me, Georg posted a very good thread about oilpan gaskets and rear mains in the FJ60 section.
Some great detail in here! Few things stood out to me. I didnt use any FIPG on the outside of my rear seal and I am thinking about getting new flywheel bolts and maybe even pan bolts. I chased mine and they look good but this thread got me a lil paranoidfound it.
I’ve been asked countless times how we install these items so I thought it was about time I’d post a thread on here about it.
I was taught how to install these parts by a couple of people with VAST experience, one of them being none other than Mudrak.
First step is to remove the oil pan. The easiest way to do this is to remove all the bolts but one towards one of the ends at the front. Next, use a putty knife, or a very thin chisel, and working forward from the back of the engine, taking care now to gouge the engine block itself.
Then remove the remaining gasket and any...
- orangefj45
- Forum: 60-Series Wagons
