Wanted F/2F engine oil filter housing
Poser
Oh...Durka Durka Durka.
Supporting Vendor
MN
Anyone have one of these, like the one pictured?
If so, send me a PM with how many dollars you need for it shipped to 55024.
Thank you!
That is a spin on filter. The F motor had a cartridge didn't it?
1969 model year F engine changed to spin on filter with the oil filter housing bolted to the intake manifold.
In 1974, with the F.5 engine, a similar oil filter housing moved to the passenger side by the fuel pump.(sans oil pressure sending unit)
The particular filter base shown in this picture is from a 2F engine,(without an oil cooler) as the F engine oil filter base would not have had the port for the oil pressure sending unit, as it was still on the left rear corner of the engine block, until the 2F, where it moved to the right side of the engine block, and remained there to the end of the run.
