Electronics Issues with audio and climate controls (1 Viewer)
Boise, ID
So, I've been noticing on my 2018 that each time I let the truck set, such as during my work day, and come back and start it, it is like the audio and climate controls electronics package takes about 30 seconds to boot up and then seems to reset to some preset values. So, I loose my Bluetooth connection to my phone and the temperature settings set themselves to 75 deg. F regardless of what I had them set previously. No error codes and climate controls function ok after the boot up. Audio typically needs a restart and then it will connect right up.
Any ideas what may be happening? Anyone else seen this?
Thanks in advance.
Jonathan
Bad battery connections (loose/corrosion) or a battery on its way out? Any starting issues?
No starting issues. I had the same thought regarding the starter battery. I may do a battery swap this weekend just to see if this might be a simple resolution.
