Electro-Beckham mig welders (1 Viewer)
Naples/Big Pine Key, Fl
Just bought a Electro-Beckham 180 mig welder at a garage sale for $35, just needs a tank. Anybody know anything about these? Apparently they're West German and supposedly good quality. Also preference on gas, argon or argon/c02 I believe are the choices right?
Seems nice, time to play.
i haven't heard of the brand before. The gas you use depends on what you will be welding. I've got an argon tank for aluminum and a co2 tank for mild steel. Straight co2 tends to make the weld splatter so i would suggest a co2/ argon mix at 25% argon. Other people might be of more help.
well, was curious, did a search for electro-beckham, only thing matching was this thread :flipoff2:
so instead of posting that link, typed in beckham, came up with link to elektra beckum, must be the same thing?http://www.metabo.com/eb/com/en/produkte/migmagweldingmachines/
let us know how it works. wouldnt mind finding a $35 welder
CO2 more splatter and deeper penetration and we all like that. Argon/ CO2 much less splatter but not as deep a penetration. You just need to up the amperage a bit.
Post up on the hobart forum site and ask if anyone knows anything about them. There's a few guys over there that probably would know.
congrats on the pickup. For mig you'll want C25 unless you're doing aluminum (then you'd want 100% argon).
FYI, you should be able to run that with flux core and no tank to learn, then add gas later on with solid wire.
Don't buy Forney flux core wire. That stuff bites. Tons of splatter and smoke. I like the Lincoln .035 flux core wire NR-211-MP and it welds almost as clean as some of the mig setups I've used. With a 180 unit, you might look into the .045 wire of the same make. Good stuff.
White Shark, you might have advised that he look into the cost/availability of a liner capable of using .045" wire - the machine comes capable of running .6 - .8 mm wire. ;)
fsusteve,
Great score! If the website linked above is showing your new welder it's able to run at full power 3.5 minutes of every ten minutes (35% duty cycle at 180 amp) which indicates a well built machine. Probably costs over $1300.00 new.
