Asking $350
Located in The Bay Area, Ca
Been used for about 10 months, still works great. Has some light scratches from offroading trips from gear inside cabin. I will include my mounting system and hooks.
Here are the specs:
This Portable Fridge / Freezer offers premium quality and innovative design to your frozen/refrigerated needs. This freezer is great for RVs, boats, campsites, fishing trips and truly portable so you can take your fridge / freezer anywhere! All you need is either a standard household 110 Volt outlet or a 12 Volt power source, like an automotive battery.
Whether on a day trip or major expedition, you can easily keep your food and beverages chilled, or frozen with this benchtop freezer. The Whynter portable freezers should not to be confused with less effective 12 volt novelty and beverage type "coolers", the Whynter portable freezer fridge is a true freezer/refrigerator which cools between -8°F to 50°F. A cost effective and mobile solution for your recreational and critical freezing requirements.
Model Specifications:
Capacity: 45 Quarts or 60 Cans (12FL oz) Capacity
Operates as a refrigerator or freezer
Compressor Cooling System
Voltage power AC (110V - 0.7A) or DC (12V - 2.5A Car Lighter Socket)
8' AC power cord and 6' DC power cord are included
"Fast Freeze" mode rapidly cools to -8°F
Adjustable temperature range: -8°F to 50°F
LED temperature display
Power low indicator
Insulated lid and walls
Two removable wire baskets
Side handles for easy mobility
Floor drain for easy draining
Functions even when tilted 30°
Tough and solid outer casing
ETL approved
Internal dimensions: 18.5" W x 11.5"L x 15" H including a compressor step with 7.5" W x 11.25"L x 8" H
External Dimensions: 24" W x 18"L x 21" H
Weight: 45 LB
Warranty: One year labor
Here are the specs:
Power low indicator
ETL approved
Weight: 45 LB
