DuraLine™ Winch Lines
If you have ever been stuck between a rock and a hard place you know how important it is to have a strong and reliable winch line. DuraLine™ Winch Lines are premium, sleeved synthetic winch lines that won’t break the bank and are strong enough to get you out of the worst of situations.
The DuraLine™ Winch Lines are made out of Dyneema SK75, which is the strongest and most UV resistant material in the world for synthetic winch lines. The DuraLine™ Winch Lines will have 5-foot polyester sleeve on the thimble side and a 10-foot sleeve on the drum side of the winch line. The polyester sleeve on the thimble side of the line will protect the winch line from abrasion against rocks, trees, and other hazards. The red sleeve on the drum side will protect the winch line from heat generated from the winch drum and will also let you know when you have let too much winch line out.
All DuraLine™ Winch Lines are supplied with a black powder-coated stainless steel gusseted thimble. 3/8” DuraLine™ Winch Lines are supplied with a G80 Heavy Duty Winch Hook, and the 5/16” DuraLine™ Winch Lines are supplied with a zinc-plated G70 winch hook.
Diameter Length Breaking Strength
3/8” 50’ 18,000 lbs
3/8” 75’ 18,000 lbs
3/8” 100’ 18,000 lbs
5/16” 25’ 13,000 lbs
5/16” 50’ 13,000 lbs
Available Options:
 DuraLine™ Winch Line, 3/8” x 50’, 303501, $229.95
 DuraLine™ Winch Line, 3/8” x 75’, 303502, $313.95
 DuraLine™ Winch Line, 3/8” x 100’, 303503, $366.45
 DuraLine™ Winch Line, 5/16” x 25’, 303504, $114.45
 DuraLine™ Winch Line, 5/16” x 50’, 303505, $166.95
The post DuraLine™ Winch Lines appeared first on RockCrawler 4x4 and Offroad Magazine.
Related posts:
  1. DuraLine™ ExoShield Winch Lines
  2. Trail-Gear Heavy Duty Winch Hook
  3. Rock Recovery™ Winch Line
Continue reading...
