I just did this with a bunch of Elm. Depends on how fast you want to dry it.
I needed to dry it very rapidly as the wood was starting to mold, and we were getting buckets of rain, so leaving it outside was no longer an option.
The fastest way is to make a kiln. For a kiln to be effective, you need a way of removing moisture from the air. I simply used a empty room I had, stickered the wood up (the more spacing you have the better), and put a dehumidifier in the room. Couple of fans to keep the air moving through the wood.
Using a dehumidifier is very quick, but not very cheap. Plus the moisture is very acidic, and corrosive to the dehumidifier. If you're just doing it once, you shouldn't damage anything, but drying wood repeatedly could be a problem. There's been plenty of kilns that had their dehumidifier short out and catch on fire....obviously not a good thing when they're sitting next to a perfectly stacked bonfire!
The more traditional way (if slower) is to basically build a room, heat it up to get the wood to release moisture, then vent that moisture laden air to the outside. Doesn't work very well if it's raining a lot, and can be pretty slow. You have to watch how much air you're moving very carefully as well, if you move too much then it's not effective. Too little, and your wood will just mold.
One of the better ones I've seen is basically a greenhouse with some solar panels powering fans to move the air through the stack of wood. With some small vents in it to exchange air, the sun naturally heats up the interior and will draw moisture out. At night the cool air will allow the wood to reabsorb some of the moisture back in which helps with checking, splitting, and warping. This method is slow (I've read that it can take as long as 6 to 9 months!), but cost free after the initial investment and tends to produce good batches of wood.
What type of wood are you looking to dry and how quickly do you want to dry it? Some types of wood doesn't handle being dried quickly very well. The Elm that I dried had no problems with being dried in just 3 weeks, but Elm is extremely tough wood. Lots of other wood would split or check, not much good if you throw away a quarter of your wood because you have to cut the ends off due to splits.
