Driver Door Courtesy Light Issue
Harrisburg, PA
Having an issue where the courtesy light in the driver's door is not lighting up when the door is opened. The overhead dome light does come on but not the light in the door itself.
All other door courtesy lights and dome lights work just fine. I have tried replacing the bulb and it did not solve the issue. Tested the plug with a multimeter and found no power is being sent to the wiring there.
Any thoughts on what could be the cause? Haven't checked any fuses yet however searching around on here has led me to believe that all the door courtesy lights are on the same fuse. Is this the case?
This is on a 2000MY
Likely when the door card/panel was last pulled off the person forgot to plug the light back in. You do not have to pull completely off the door, just remove the necessary screws/bolts and pop the panel to allow to swing from top. That should give you enough room to look inside and see if plugged in from behind.
