Does anyone know the unloaded length of the OME rear springs for a 100? (1 Viewer)
Thanks.
485 mm for OME 864's but I doubt that's any help to you!
864's are for the Turbo Diesel, heavy duty, plus 800 lbs, 10 mm height increase as I recall, I don't have a copy of the spec sheet with me, the 863's / 865's are possibly for the V8 and give an increase of 50 mm IIRC
865's are 18 and 1/8 inches measuring from larger base (top mount) to the highest point on the smaller base (lower mount). These are new, never installed springs sitting on my work bench calling me to get them on my 100............today.
Not sure what that means in mm's.
Jukelemon -- and other -- thanks -- that's just what I was looking for. I post my finishd project in a few weeks. Basically a one inch lift (ARB Tbars -- Slee diff drop front) and Auz rear springs with what I'm hoping is only a 1/2-3/4" lift but similar spring rate to OME...... !!! Thanks again.
OME 865s(rear 100, medium load to GVM)
are 18mm bar diameter, free height 460mm, 8.3coils, spring rate of 220lbs/in
OME 866(consant load 200kg to GVM)
18,465mm ,9 coils, 240-300 lbs/in
I think any of the 80's rear coils are also an option, such as the 863, 864 and will result in more lift than the 2 coils listed for the 100
either the candy or milimeters :D
Damn Pimp, you know that might be close in terms of nominal difference ( :
