- Joined
- May 15, 2006
- Threads
- 108
- Messages
- 1,382
- Location
- Chandler, AZ
- Website
- www.claritypoolservice.net
I have tried to go through the archives to find the solution to this, and have exhausted my resources (=patience) in finding similiar solutions. I recently treated my 76 to new axles, F & R, and did a disk swap kit in the back on the drum axles I swapped in. Here is my problem, when I did the disk work, i decided to replace the master cylinder (original = leaking) with a new AisIn model from japan. My challenge is I am a fabricator, not a very good mechanic, and I cannot get the front output on the new master cylinder to pressurize, and push fluid. Is their a special way to prime a new master cylinder? Should bolting it up and filling it with fluid not be enough?
The output line closest to the fire wall seems to pump fine, but the front output doesn't seem to have any pressure at all. The master cylinder is brand new, not reman, so am Imissing something obvious? As I previosly stated, I am not a brake mechanic, but I am not a rookie to turning wrenches by any means.
Any thoughts?
Any thoughts?
