So, decided to document what it took to install a new brake master cylinder, bench bleed it, bleed the brakes, adjust rear drums from a first-timers perspective - hope it helps someone. lots of info in various places here and on web, but often assumes some experience (I had 0) and info is spread out. So, here are the steps I used for my setup of front discs, rear drum, brake booster - and had awesome results! results made me realize just how bad my brakes were... I could actually lock up my rear drums after this!
new MC - note 2 larger reservoirs
1. got a new Toyota MC (part #47201-60010)
2. removed brake lines from side of MC
3. remove old MC (4 nuts hold it to brake booster) and dump old fluid
4. removed larger reservoir from old MC and swapped it out with smaller reservoir on new MC to have 2 large reservoirs on new MC
5. pull out the plunger on the brake booster a few inches or so and place the MC on the bolts and push it into place. then, pull it off and see how much plunger play exists back into the booster (and make any adjustments necessary at the brake booster if needed - mine did not require). GOAL I understand is to not have the plunger pushing/pressure into the MC and actuating it during this mockup. this was the best way I found to test that the plunger sits in the MC just perfect without actually actuating it when it is finally bolted on. (NOTE: adjustment of the plunger depth in and out in the brake booster is by turning it.)
6. bolt on new MC
7. remove residual pressure valve (spring and black plastic valve) from under front brake circuit copper nut on MC since I have front discs - I left in rear one as I have rear drums. this is on tight enough I found it had to be done while bolted to rig. easier that way. (NOTE: this will be relative to your year of rig and MC if the valve needs removal).
what the residual valve looks like
bench bleed
1. MC bolted back to rig - (yep, 'bench' bleeding it on the rig contrary to some and similar to others advice on doing it off the rig in an actual bench vise - it worked perfect)
2. finger tighten (not snug mind you) brake lines b-nuts
3. fill both reservoirs
4. actuate brakes numerous times until fluid flows freely from around both hand tight brake line b-nuts
5. tighthen up brake lines and top off reservoirs
6. actuate brakes final few times to make sure no leaks at the b-nuts/brake lines
brake bleed
1. started with rear drivers side & on front most cylinder bleed nipple - remember that on this model/year, there are 2 nipples to bleed per wheel (FWIW, could start with front passenger - just start in circuit farthest from the circuits reservoir and stay with that circuit until done).
2. removed the dust cover from bleed nipple and unscrewed with #10 open ended wrench about 1/4 turn - feeling of loosness is obvious - too loose and fluid will come out around threads and all over versus through nipple (where it should) during bleed process
3. attached a brake bleed hose kit from Pep Boys ($5, has a long clear tube, 1 end attaches to nipple and other is 1 way valve on end to stop air from flowing back but fluid to flow out) to the nipple and end into collection container
4. acutuate brakes until fluid flows - WATCH to keep reservoir topped off - with no bubbles.... then give a few more pumps just to be sure it is 100% fluid and no air bubbles.
5. snug up nipple, top off reservoir.. do it again on the rear most cylinder on that same wheel in that circuit
6. snug up nipple, top off reservoir.. now do it again on that circuit, but next wheel front cylinder (if you have 2 nipple drum brake)... finish and then move to next circuit.
Pep Boys device attached to nipple - Part# W170C
drum adjust
1. jacked up rear end and put on floor jacks
2. spun drivers wheel to see if free spin - it did
3. using a screwdriver (though there are specific drum adjust tools) I tightened through the rear cylinder adjustment hole (there are 2 - 1 for each cylinder as noted above that correspond to each nipple) the nut by pushing it AWAY from the axel (towards rim edge). did it several times and then did the one for the front cylinder several times - tried to do them equal amounts though I understand it does not matter. did it enough until I could not spin the wheel free (in my case - like 10-15 clicks).
4. pushed brakes to make sure pads were centered and tested spin again - still tight
5. backed off adjustment I just did 5-6 clicks (screwdriver towards axel) and tested spin - spun free
6. pushed brakes to make sure pads were centered and tested spin again - spun free still
5. moved to other wheel and repeat
NOTES:
a. 1 32oz. container of brake fluid - high end Castrol - was plenty enough for this entire process (a few oz's left over actually)
b. be sure to see if your drums have 2 bleed nipples or 1 - mine had 2 on each of the rears (4 total to bleed for rear)... don't ask how I found out
c. that $5 Pep Boys device was so worth the price of admission! 1 way valve so no air back into system, hose long enough you can see it bleed at any wheel while still actuating brakes. nice.
d. in the 'drum adjust' section: techincally - you are not really 'turning' anything in the sense that you might turn a lid on a jar with your hands, you are more ratchiting and pushing or pulling the tool/screwdriver which in turn then 'turns' a gear inside that makes the adjustment. the concept of 'turning' something confused me when researching this topic as that was the default word people used, but it is not really the accurate motion you would be doing though your motion does result in the something turning inside the cylinder.
thanks Steve for all the help and tips/advice
6. bolt on new MC
bench bleed
brake bleed
drum adjust
NOTES:
