disconnecting power to the antenna
Alabama
I searched and couldn't find anything. So here goes...
Is there a way to disconnect the power to the antenna without messing up the stereo? The cord in mine is broken and the motor runs at start up and shut off even though I only listen to cds and XM (through the tape player). I don't want the motor to burn out before I can get a new antenna mast installed.
Thanks,
Sam
There's a standard socket plug that you can disconnect and that will kill power to the antenna. Open the hood, follow the wires from the motor and disconnect it!
Is it inside the fender? I can't get my big hands in there or is there something I missing.
If you can't get your hand in there remove the bolt that holds it in place, twist the assembly a bit and it will come out far enough for you to access the plug.
Ok cool, thanks for the help ya'll.
