Difference in the 4wd Systems 2020+ Sequoia SR5 vs. the TRD Pro?
Texas / Florida
*I believe the SR5 is open front & rear diffs where the Pro has a LSD, correct?
*Does the TRD Pro have A-Tracs?
Thanks guys!
Thanks guys!
I don't think the 4wd system is different between the two.
Both have open diffs
Both have torsen limited slip center diffs that can lock.
No mts, atrac, or crawl
The 3rd gen 23+ pro will have different features such as locking rear diff, crawl, and mts.
Thank you for your responses.
Seems like a ball drop on the PRO and almost strange, but it works in my favor as I wrestle between a lightly used '22 SR5 and '20-'21 PROs for $10-13K more with more miles as I have locker, lift, tires and gears planned anyway...
Partially correct answer. No difference in 4wd system. Other than a rear locker, it's pretty much the best selectable 2WD/AWD/4WD Hi/Lo system Toyota has. MTS and Crawl Control are just electronic gizmos. The 2nd Gen Sequoias do have ATRAC, it is automatically on when in 4WD Lo with centre diff locked.
